So I've installed viper 5704 alarm on my wife's 06 xB 5speed over the weekend but i'm having some problems with it. Also added glass break sensor and tilt sensor, just haven't tested them yet. The only functions right now is door/lock unlock and shock alarm. Cant get remote start to work, getting an error message on my remote and headlight flash 7 times which means manual transmission mode is off. Cant enable MT mode with remote, tried a few times. Also can't pair my remote with the brain, tried from remote functions and using control button on the antenna. I don't understand how I'm able to use remote to lock/unlock and read messages, but its not paired? Here is my wiring, let me know if i missed anything. Thanks
Main Harness
h1/1 red const 12v - tap to a const 12v white/red - ignition harness
h1/2 black grnd - chassis ground
h1/3 brown siren out - connect to sirens red (black to ground)
h1/4 white/brown park light isolation wire - not used
h1/5 white park light out - tap to park lights green wire - headlight switch
h1/6 orange ground when armed out - not used
Door lock
1 blue out - tap to neg unlock -yellow/black -driver kick
2 empty
3 green - tap to neg lock-blue/white -driver kick
Aux/shutdown/trigger harness, 24-pin connector
h2/1 pink/white ign/flex relay out - not used
h2/2 black/white neutral safety input - tap to e brake -black
h2/3 blue white 2nd stat/rear defog out - not used
h2/4 green black oem alarm disarm out - not used
h2/5 red/white trunk release out - not used
h2/6 green door trigger in - tap to door trigger red/white - fuse box 9pin
h2/7 black/yellow dome light supv out - same as door trigger
h2/8 brown/black horn honk - tap to horn white/red-steering column
h2/9 dark/blue status out - tap to clutch switch-black/yellow
h2/10 pink ign out - not used
h2/11 white/black aux3 out - not used
h2/12 violet door trigger in - not used
h2/13 white/violet aux1 out - not used
h2/14 violet/black aux2 out - not used
h2/15 orange/black aux4 out - not used
h2/16 brown brake shutdown in - tap to brake wire switch green red-brake pedal
h2/17 grey hood pin - to hood pin
h2/18 violet yellow starter out - not used
h2/19 blue instant trigger in - not used
h2/20 grey/black diesel wait to start - not used
h2/21 white/blue remote start/tt acvt in - not used
h2/22 orange acc out - not used
h2/23 violet/white tach in - tap to tach black wire- obdII connector
h2/24 oem alarm out - not used
remote start 10 pin heavy gauge connector
h3/1 pink ign in/out - tap to ignition black - ignition harness
h3/2 red/white fused ign2/flex relay in - not used
h3/3 orange accessory out - tap acc blue/red - ignition harness
h3/4 violet start out - cut black starter wire then connect this to starter side
h3/5 green starter in - key side of cut starter wire
h3/6 red ign in - tap to const 12v white/blue-ignition harness
h3/7 pink/white ign2 out - second ignition black/yellow-ignition harness
h3/8 pink/black flex relay in - not used
h3/9 red/black acc/starter in - tap to const 12v white/blue-ignition harness
---------- Post added 07-16-2012 at 05:32 PM ----------
Oh and I tried to disconnect the battery for 30min, still doesn't work.
Main Harness
Door lock
2 empty
