Well I came across another salvageable part at work. The 3rd brake light out of a 05' BMW Z4 roadster, lens was cracked so I took it apart and used the LED strip out of it. With some flat black paint double sided tape and about 20 minutes it was done. The strip is thin, less than a 1/4 inch. About 3/4 inch tall, nearly a foot long.
Sprayed it flat black, (taped off the LED's)
Used a 8" piece of 1/4 inch wide double sided tape,
Removed the original light,
Wired and taped it on the hatch over hanging the window.
Doesn't look at all bad on the inside, very clean, but it is there.
Note: Rain on window
Last pic is at about 40ft away.
