1 - 4 of 4 Posts
Ever since they came out, I wanted one of these little bastards.
I finally bought one used, and it has been an adventure.
Two new front window motors, and every door lock actuator in the car have been replaced at this point.
I don't mind, rockauto.com is awesome, and these parts haven't been difficult to replace.
The only real potential problem is, the AC is not blowing very cold.
I connected the refrigerant can with the gauge on it, and it says the charge is adequate.
It seems to blow air well enough, it just isn't cold enough.
Any insight?
PS, I am terrible with forum formats, so please forgive any faux pas.
Thanks
Welcome to da club !!! I am not good at AC but looks as though you hit the door lock actuator problems with our box's as they get old !!! Post a picture of your xB when you can and let the mods begin !!!!
So I found a TSB AC007-04, which describes a compressor replacement. That Bulletin references another, TSB No. AC002-04, which is for an adjustment to the air mix cable. I can't locate that bulletin. Any ideas?
1 - 4 of 4 Posts
