hey guys i was just woundering can i use washers as my spacers due to the fact that 5mm spacers are to big for my rear. was woundering do you guys think this is safe or has anyone done this thanks
from what i heard washers are not good to use... they will cause your tires uneven wear and unbalance ride...
DO NOT under any circumstances use washers as spacers. That is unsafe.
If a 5mm spacer is too big you don't need to use spacers on your wheels. 5mm isn't eve 1/4".
koo thanks do you know if any one makes a 3mm spacer
well scotty what i was running was 235/40/18 in the rear and the offset are 32 so i was rubbing on the rear even after i roll the fenders. so now im running 225/40/18 all round and rubbbing in the front when i make the full turn. should i run spacers there i would like a flush look thats why i wanted to run bigger tires in the rear thanks
