1 - 20 of 29 Posts
*WHEEL FITMENT INFORMATION
(It is assumed that these figures will work on both the xA and the xB, but most are from xB owner's personal comments.)
BTW, if you have a wheel set up that's not on this chart, please post'em so that we can gleen off of your experience, and from your knowledge. Post'em!
WHEEL SIZE . . . . OFFSET RANGE . . . .TIRE SIZES . . . . COMMENTS
19x8.0 . . . . . . . 35 . . .(Front)25(Rear) 215/35/19 . . . . Rubs Slightly XB(shim kit)DenZinz
19x8.0 . . . . . . . 40 . . . . . . . . . . . . . 215/35-19 . . . . Rubs under hard cornering
19x7.5 . . . . . . . 45 . . . . . . . . . . . . . 215/35-19 . . . . Rear needs 5mm spacer: DGTLLVR
19x7.5 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . No rubbing, rear mud flap trimmed: gregp909
19x7.0 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . Rolled fenders & hammered wheelwell: matchbox
18x7.0 . . . . . . . 28-32 . . . . . . . . . . .215/35-18 . . . .foxSCION "no rubbing"
18x7.0 . . . . . . . 40 . . . . . . . . . . . . . 235/35-18 . . . .K4kas no rubbing xB
18x7.5 . . . . . . . 35 . . . . . . . . . . . . . 215/35-18 . . . .Front tire rubs at full lock
18x7.5 . . . . . . . 35-42 . . . . . . . . . . .215/35-18 . . . .Silkywilson et42
18x7.5 . . . . . . . 42(Front)(35)Rear . . 225/35-18 . . . .Oneslowxa 2"drop tanabe sustec pro
18x8.0 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x8.5 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x9.0 . . . . . . . 31 . . . . . . . . . . . . . 225/40-18 . . . .rampagesd
17X7.0 . . . . . . . 20 . . . . . . . . . . . . . 205/40-17 . . . .quadoptix xB
17x7.0 . . . . . . . 28-42 . . . . . . . . . . .205/40-17
17x7.0 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . . .TheScionicMan
17x7.0 . . . . . . . 38 . . . . . . . . . . . . . 215/45-17 . . . . xB stock
17x7.5 . . . . . . . 30-40 . . . . . . . . . . .215/40-17 . . . .
17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . .3mm Spacers CBSIMONSEZ xB
17x7.5 . . . . . . . 38 . . . . . . . . . . . . . 215/40-17 . . . .Stock xA Leinad
17x8.0 . . . . . . . 25 . . . . . . . . . . . . . . . . . . . . . . . .dropped 3.5-4 inches, rolled fenders, rubs like two horny fat people with any dip or person in the back seat . . . scionscotty
17x8.5 . . . . . . . 16 . . . . . . . . . . . . . 215/40-17 . . . . Front doesn't rub: Oper8r
17x9.0 . . . . . . . 17 . . . . . . . . . . . . . 215/40-17 . . . . Rear rollled fenders: Oper8r
16x7.0 . . . . . . . 33 . . . . . . . . . . . . . 205/55-16 . . . . Front rubs slightly in front: oj411
16x7.0 . . . . . . . . . . . . . . . . . . . . . .205/55-16 . . . . No rubs: The Zeeness
16X7.0 . . . . . . . 35 . . . . . . . . . . . . .205/45-16 . . . . Stock xB: Pushytop
16x7.0 . . . . . . . 25-35 . . . . . . . . . . 205/40-16
16x7.5 . . . . . . . 38-40 . . . . . . . . . . 215/40-16
15x6.5 . . . . . . 35 . . . . . . . . . . . . . 185/60R15 or 185/65R15 (xB and bB stock sizes)
15x7.0 . . . . . . 38 . . . . . . . . . . . . . 185/60-15 . . . . Stock Size xB
15x8.0 . . . . . +25front +10rear . . . . 195/50/15 Tein Basics all the way down. no rubbing but my rear fenders are rolled . . . Infekted
15x8.0 . . . . . +25mm F/R . . . . . . . . . 205/50/15 - Dropped 2" on goldlines - no rubbing at all. (Axis OG Old Skools) EticketXb
15x8.0 . . . . . . 23F. .18R . . . . . . . . .205/60/15 2" ground control Minsk99 xB
15x8.0 . . . . . .et0 F/R . . . . . . . . . . . 195/50/15 3" Drop on D2 Coilover -2F -5R Camber. Inside fender grinded 1/4. Rubs little with full load going over 90mph through a low dip. ThunderGod
MISC INFORMATION
Scion xA and Scion xB Specifications:
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
15"x6" +38 offset / 185/60R15 xB 185/60R15 xA 185/65R15 bB
37 lbs per wheel & tire
Alloy wheel: 16.7 lbs
Other Vehicles With Interchangable Wheels
Toyota Celica (1988-1989)
Toyota Corolla (1988-2001)
Toyota Corolla Wagon (1988-1996)
Toyota Echo
Toyota MR2 (1986-1990)
Toyota Paseo
Toyota Tercel (1989-1998)
Toyota MR2 Spyder (2000-)
LINKS SECTION
RRR-GAME
TAKUMI PROJECT
GRUPPE-S
FALKEN
TIRE RACK
DISCOUNT TIRE
(*All or some portion of this information has been attained from other "site" source, and is not my findings, or originals.)
One thing missing in the comments section is if the xB is lowered and how much.
Otherwise excellent info and if this isn't stickied yet, it should be.
nice..... NICE
Now thats a nice list for regular fitment. But shouldn't flushness count too. I think some people want to know how flush the wheel is with the fender. If that was added too that would be great.
17x8 25 offset, dropped 3.5-4 inches, rolled fenders, rubs like two horny fat people with any dip or person in the back seat.
17x8 +25
205/40/17 jdm tires
Goldlines 2" drop
Fenders NOT rolled
No camber
No rubbing
17x8 +25/15
205/45/17 dunlop direzza dz101
Blitz coils set at 2.75"
rolled fenders
no camber
no rubbing
16x9 +30/20
205/50/16 kumho asx
Shocks set at 4 out of 8
fenders rolled
no camber
no rubbing
16x9 +30/20
205/50/16 kumho asx
Cusco coils set at 3.25"
fenders rolled
-1.5f/-3r camber
no rubbing
Coming soon:
15x8 +12/6
195/55/15 Dunlop or Falken or Yokohama
Cusco coils set at 2.5"
fenders rolled
-1.5f/0r camber
rubbing - probably not, but we'll see :)
Thank you for setting this up! This will be VERY helpful once we get a large base going!
Shouldn't this get stickied??
18x7.5 with 15 off-set transfers paint on 215/35/18 with Teins, minor roll needed.
15x8 with 10 off-set and stretched stock rubber, no rub yet on Df210's
15x7.5 +38 Drag DR20s
195/60 15 Falken Ziex ZE-512s
front: 3mm spacers
rear: otg rear spacer shims + 5mm spacers
drop: megan racing springs
No rubbing with or without the rear spacers
Fronts won't fit without 3mm+ front spacers
18x7 +45 Flik Wasps
215/35 18 Cooper Zeon Zpts
Drop: Megan Racing springs
OTG rear spacer shims
No rubbing
Rubs the welds on the rear trailing arm bad without any rear spacers
Discussion Starter · #15 ·
I was alerted to this post, good info!
I think we have the same one posted on our site, with the same disclaimer.......lol
like my kids always remind me, "sharing is caring"
thats what i love about the scion community, making information available to all. :)
it's always good to have a disclaimer, it pleases other parties. :)
18 x 7.5
+42
225/40/18
Tein S tech's
OTG rear shims
monroe rear shocks
No problems with rubbing as of yet.
17 x 7 +42. 205/40/17 no rubbing at any height
15 x 8 +25 front (A disk) +10 rear (O disk). 195/55/15 rubs on rear past 2 inch drop, needs fender roll and -4 degrees of camber.
Whats with the A-disk and the O-disk.
17x7 +25 no rubbing
17x7 +25 with OTG 10mm hub spacers and camber plates: rubs on dips and with people/cargo in the car.
lowered on tanabe df210's
Eric,
Here's some more info for you.
I'm on a custom TEIN 3-3.5 inch drop(I don't really know since I never measured, but the tops of my fender openings are 23 inches from the concrete) and w/ -2 camber up front, and -3 camber in back:
Front - 18x7.5 +38 w/ 215/35-18, rubs at full lock
Rear - 18x8.5 +35 w/ 215/35-18, fender lip rolled w/ 1/2 inch clearance
I have a set of 006s, 18x8.5 w/ 215/35-18 and 18x9.5 w/ 225/35-18, but they require raising the car so the rears would fit and not rub. Others are running this set-up, just not as low as I am currently.
1 - 20 of 29 Posts
