1 - 13 of 13 Posts
Alright guys I need some help, I have a 06 Xb lowered on some TRD springs and Im looking to add some wheels for the spring... How big can I go? 18's? 19's? And are the wheels going to create a big gap between tire and wheel? Please help me out guys:confused:
since you only have a trd drop you can run 18's or 19's with out rubbing. well depending on the width and offset. but most wheels you'll be fine cause the trd springs don't have a huge drop to them like the tanabes would. what wheels did you have in mind?
all depends on the size of the tire!! the bigger the wheel the skinnier the tire, and the more careful you have to be no to bend or curb rash your wheel! i have a 18x7.5 with a 42 offset and 225/40 tire, i'm purchasing tanabe df210s which will sit lower than the trd springs
you'll be fine with those. tammie (scion doll) has those and she's fine. i have 16x9 with only 15 offset and if i had gotten the right size tire i wouldn't even be rubbing with that.
1 - 13 of 13 Posts
