not to sound like a noobie, but wat the hell is a gap in the plug?
no prob good question so i found this hope it helps out
its the gap diff gap diff spark or no spark
The spark plug's location exposes it to extreme temperature variations, chemicals, fuels and oils. It is also attacked by cylinder pressures produced by the piston and cam timing, then it is also assaulted by high-output ignition units. As a result of all of this, one can effectively learn what the engine is doing by reading the firing end of the spark plugs.
By careful examination of the plug's color, gap, and any deposits that reside on it, you will be shown the efficiencies as well as deficiencies of what is going on in the engine. Spark plugs should be checked at least yearly, and replaced as often as necessary. In most cases you can follow the manufacturers recommendations, but in a race car, our replacement intervals are quite frequent.
Always set the spark plug to the engine manufacturer's specified gap setting. A gap that is too small means that the spark duration will be very quick and the spark will be thin and weak. The consequences of this may be bad starting and high exhaust emission levels. This will result in an increase in fuel consumption. If the gap is set too large, the ignition system will not be able to cope with the demands and a misfire situation will occur. Some wide gap spark plugs have a longer ground electrode to accommodate a wide gap setting. These must be used where specified, as opening up a standard plug to a wider gap setting may result in the electrodes not running parallel to each other. This could result in abnormal and premature electrode wear.
i found this @
http://www.ngkntk.co.uk/technicaltips/sparkplugs.asp
