nice mods. clean lookin bB. i forgot that’s what the stock shifter looks like. I think mine was a severed hand prop lol.
nice mods. clean lookin bB. i forgot that’s what the stock shifter looks like. I think mine was a severed hand prop lol.View attachment 81641
The entire car has fully been converted to LED, with the exception of the HID low beams. I decided to choose white LED since the green or red looked weird to me.
even better.Thank you but that is a stock shifter from a Toyota Celica 😉 View attachment 81643
I got a purple led in my PRNDL.View attachment 81641
Friday I installed the blue fuel injectors from the 1.8L Corolla in my xB, and simultaneously removed the MAF 'sleeve' or 'insert' I'd had in my intake (to correct the P0171 lean code). Got a nice little higher-RPM power boost, happy engine sounds, and apparently it was a good set of injectors, because the car's been working beautifully!
I was hoping the higher flow of these injectors would counteract the lean code, but alas, the check engine light did return (though it seems less often than before). Still, I don't think I'll reinstall the insert... the little extra power is worth clearing a CEL once in a while! View attachment 81649 View attachment 81650 View attachment 81651 View attachment 81652
Sent from my SM-G973U using Tapatalk
This is how I did mine…
I keep an eye out on my LT and ST fuel trims
I kept the directional air vanes and used 2-6 layers of stockings to slow down the air flow. Without the stockings, after having performing the smoke test, it would throw a P0171, lean code almost weekly and that got annoying.
Ive only had to reset the ECU late winter after experiencing P0172 rich code, which resulted from a dirty filter, possibly from extreme cold, moisture and road salt particles.
I haven’t had any codes since cleaning the MAF last January and only using 3 layers of stockings inside my BLOX filter. Thats about 1500 miles ago.
Well done! Great idea.Friday I installed the blue fuel injectors from the 1.8L Corolla in my xB, and simultaneously removed the MAF 'sleeve' or 'insert' I'd had in my intake (to correct the P0171 lean code). Got a nice little higher-RPM power boost, happy engine sounds, and apparently it was a good set of injectors, because the car's been working beautifully! Sent from my SM-G973U using Tapatalk
Your xB evolution continues with excellent mods.I installed these over the weekend. Originally was going to go in the second lower grille area where those two little pieces are, but this seemed like a better choice. Pretty bright for what it is and it seems pretty stable.
