14381 - 14400 of 15171 Posts
Glade to see you back!
---------- Post added 11-05-2018 at 03:58 PM ----------
Daytime, 6000k
I’m loving the clear corners
---------- Post added 11-05-2018 at 12:38 PM ----------
Well, the whole front end in general but the clear corners are real nice. Maybe one day I’ll clear mine out or get some JDM ones
You just need some fog lights to compliment the new lights
My fog light covers are permanently reinforcedfrom the back, thank you though.
---------- Post added 11-05-2018 at 08:35 PM ----------
U have part#
Got it off Ebay, here is the link.
https://www.ebay.com/itm/LASFIT-LA-Series-9003-H4-HB2-LED-Headlight-High-Low-Beam-Flip-Chip-6000K-7600LM/302251417313?epid=1976912831&hash=item465f969ee1:g:kT4AAOSwdnZaRPNv:rk:1:pf:0
---------- Post added 11-05-2018 at 09:48 PM ----------
At RS2SYBOX
Clearing stock corners is easy. Take the headlights out, get some needlenose pliers and a screwdriver, and have at it. Breaking the amber plastic and shaking the headlight to get the amber pieces out.
man, i just replaced the bulbs on my wife's Sonata. If I was a bit more proactive I would have bought 2 sets of these LEDs and swapped those in for hers and my box.
Dang, it would definitely add to the brightness. I love how my fogs compliment the headlights.
At RS2SYBOX
Seriously? I thought I had to bake them open. Pardon my french but f*ck yea! Definitely going to do this. I just got some extended length needle nose pliers too
---------- Post added 11-06-2018 at 12:03 PM ----------
I got some from Auxbeam, well all my cars have them. Inexpensive and good products. Not to say the Lasfit aren’t, but its an option
Yup, long needle nose are perfect. If those work for you great. I had questions when I was looking to upgrade but didn't find too much on LED bulbs, so I did some research and pulled the trigger on them. Now I'm sharing my experience and pix for others that may be looking into LED bulbs.
Sweet. I know what I’m doing this weekend if not sooner. Thanks for the tip!
The main thing that I kept reading about LEDs is to find one that mimics the filament position more so than anything. I had some from SuperBrightLEDs (which by the way have a great selection of other LED bulbs for not only your car, but home and business as well) which worked good but I wanted something brighter so I tried those and they worked good
xB Leaving Pit Soon
Re: What I now want do to the xB today!
Well heck Samy, I was done with xB mods for a while, but now you have me researching LEDs. I removed the HIDs, which had a lousy beam pattern, before the xB went away, and put in SilverStars, They gave a better light dispersion than the HIDs. On my next trip to Kentucky I will check the xB for distance behind the TYC lamps to accommodate the H1 LED bulb length. I know I have to cut into the four TYC access covers; and add a watertight boot.
picked this up last night off craigs list for 40.00. Just have to go though the box of couplers to get it installed
It also iced and snowed last night so it is now the time to take the tein coil overs off and the trd 18's to go back to stock and winter tires
Old School xB Builder
Make sure that thing has a bypass valve on it before you put it on. I have blown two engines that way without a bypass valve.
Sent from my LG-LS997 using Tapatalk
  • Like
Reactions: se-r_dad
New steering wheel...
Whaaaaaaaaaat!!!!!!
I can say that has probably never need done before
---------- Post added 11-07-2018 at 05:44 PM ----------
Ray you are a Mad Sciontist.
