1 - 4 of 4 Posts
i ordered the perrin crank pulley and i was wondering if it's hard to install? also someone told me that if i install it my timing will be thrown off......
Seriously, just do it yourself, unless you wanna spend an arm and a leg.
A buddy of mine and his soon to be father in law toyota mechanic installed mine. Took em a couple of hours.
We had NO problems with anything. Take off crank screw, loosen the belt, pull off stock pulley without moving anything, install perrin, bolt it on, tighten belt, re-check crank pulley for tightness.....bam, you're done!
1 - 4 of 4 Posts
