1 - 5 of 5 Posts
so im sitting at or around 30,000 and im certain there has to be some stuff i need to replace, aside from the normal stuff like oil...but what im talking about are spark plugs or any or thing you peeps could think of that needs to be replaced...please type down what you know of up keep for the xbizzle:eek:
yup the 30k I think is plugs,oil/filter,pcv valve, air filters,trans fluid, coolant, rotate & balance,inspect & clean & adjust rear brakes. you might want to take it in for future warranty purposes. or at least keep all your reciepts.
Box Luvin
Recommended 30,000 Mile Service
• Replace engine oil and oil filter
• Install BG MOA
• Drain and replace transmission fluid
• Drain and replace differential fluid
• Coolant system service and inspection
• Flush and refill coolant system
• Pressure test coolant system, hoses and connections, tighten clamps as required
• Inspect radiator cooling fan operation at proper temperature
• Inspect water pump for leaks and operation
• Replace spark plugs (non-platinum)
• Major tune-up including:
Perform fuel induction service
Replace air filter and breather element when applicable
Inspection of ignition system and spark plug wires
Set ignition timing, idle speed and test vacuum and mechanical advances on distributor as required
Replace PCV valve
Inspect throttle control unit
Inspect air intake control system and operation
Clean and inspect fresh air hose
Clean and inspect hot air hose
• Test and inspect emission control devices and charcoal canister
• Inspect exhaust system and hangers for leaks and tightness
• Inspect fuel lines
• Adjust and inspect all accessory drive belts and pulleys
• Battery and charging system inspection analysis including: clean, inspect and tighten battery connections. Load test batteries. Test alternator charging output.
• Clutch adjustment (when applicable)
• Lubricate recommended areas including hinges and latches
• Brake servicing including:
Remove wheels and inspect front and rear brake pad thickness, brake rotor condition, seals and bearings.
Adjust emergency brake and brake system when applicable.
Inspect brake hoses, lines and fluid level.
Inspect for leaks or damage.
• Suspension checks and inspections:
Inspect steering rack and components
Inspect tires for wear and inflate to proper p.s.i.
Inspect front and rear suspension components (shocks, struts, etc.)
Rotate and balance all four tires and wheels
• Check operation of all lights
• Road test for following:
Overall engine and transmission performance and quality
Overall handling and braking performance and quality
Wheel balancing
Alignment tracking and steering wheel position
Air conditioner operation
• Reset service indicators (when applicable)
1 - 5 of 5 Posts
