having same issue but all blubs are on
the front left side is very dim..
can i get the bulb out without have to remove light assembly?
addicted
Anytime I've experienced hyper blinking was from a bad fuse. Otherwise if you have LED's replacing your factory bulbs those will cause a hyper blink if they're not on the proper resistor.
Hi,
Also, if you run LED turn signals, you could swap out the relay with one prebuilt for LED resistance levels.
---------- Post added 05-27-2016 at 04:58 PM ----------
Oops... Also, I recall having this issue several years back and the problem was that one of the front trun signal sockets had gotten some corrosion in it, so the bulb acted as if it was blown....had to clean the socket & bulb with some gentle sanding and reassemble tp clean up the ground points of the circuit.
turn signal is blinking fast; light is flashing fast to one side only
I had the same thing going on in mine, it turned out to be a loose connector on the left front blinker bulb, pushed on the connector and problem solved
