I am building a turbo set-up for my '98 Tacoma 2.4L 2RZ-FE with 5-speed. I have the turbo picked out, the manifold built, the intake is in production...but I need help with fuel management. I don't know if just a bigger pump and injectors will be enough or if I need a piggyback ECU. Also, will the Apexi SAFC-II do the job or do I need something better like a Split Second AFC?
I will be running a t3/t4 stage 3 turbo with 7-8 LBS boost...I will be surprised if I see 9 PSI and will never go over that. I am putting headstuds in and cometic head gasket. I want this thing to be reliable and drivable, so I don't want to take shortcuts here and there.
I am very lost on which direction to go, so ANYONE with turbo knowledge is needed and welcomed to chime in! Thanks in advance!
