1 - 13 of 13 Posts
i copped the sportmax 962 rims.. but i need some tuner lug nuts.. but i don't know where to buy'em.. any ideas? or names of stores? thanks.. and if you do have lug nuts for the rims.. any specific brand? let me know.. ASAP thanks!
EMAIL ME @ [email protected]
AIM @ xfLipm0d3x
Thanks guys!
superjeer said:
Autozone, etc work. Just make sure NOT to get the ones that are not capped. the open ones will rust.
i tried kragen.. maybe ill try autozone tomorrow.. thanks guys! once i find'em i'll have my rims on :)
Whats the difference between tuner lugnuts and standard?
Tuner lugnuts use a special key and have thinner wall and deeper and come in different colors. I bought mine for about $35.00 on ebay. Standard are what you see on stock rims. 12mm x 1.5
yeah, a std lug needs a normal socket and usually tuner wheel's holes aren't big enough for the socket. So, tuner lugs use a key/thin walled socket so you can get them on and off. I reccomend the kind where the sicket.key goes on the outside of the lug and the lug is closed as ooposed to the kind where the key goes on the sinde and you can see through the lug. The second type will rust real quick. 12x1.5mm's will work.
autozone had them.. thanks! 25$ :) YAY!
1 - 13 of 13 Posts
