Hello everyone,
The TPMS light came on this weekend. The light blinked several times and then turned on. Based on my research, this tells me one of the sensors is bad. I took the car to Discount Tire and filled air up to 35 psi per tire. The light continued to blink and then was static even after filling up the tires with air.
Discount Tire told me it would be $60 per sensor and recommends I change all 4. No way am I going to spend that kind of money and pretty sure I can get a set of 4 cheaper on EBay.
Have any of you run into this problem, and if so, did you end up changing the sensors? Some have said not to worry and just monitor the air in the tires weekly or so. I don’t mind doing this but afraid if I car would pass inspection or not (I live in a state that requires it).
Thank you.
Thank you.
