1 - 9 of 9 Posts
Didn't know where to post this..... tried a couple sections under 2nd gen, but no replies....
I usually buy Hidden Hitch brand receivers, but no such thing for a 2008 xB. Is there any consensus on some of the better hitches (ease of install, how hidden they are, how easy to connect wiring). I'm assuming most get a class 1 ?
thanks
2006 Scion XB
thanks
I recommend you try searching your vehicle at https://www.summitracing.com/search...atch&SortOrder=Ascending&keyword=Towing hitch
They have three different type for your Box
Hope it helps 👍🏼
I have used a REESE universal fit on my 2009, worked fine with one mounting plate had to be cut for clearance.
Still solid at 105 k miles , my car is a 5 speed with 205 50 16 tires for slightly lower gearing.
I've towed many thousands of miles with a 500lb trailer and a 500lb motorcycle.
Power is sufficient for a big grade in 4th , Brakes are sufficient for MOST downhills (Glad I can downshift my standard)
79526
79527
summit has 3 options for 1st gens and 3 for 2nd gens.......
1 - 9 of 9 Posts
