1 - 12 of 12 Posts
Bolt pattern universal 4 x 100 wheel width 18 x 7.5 with a 42 offset
is this correct to fit on my xb? thanks
Yep, they will fit as others have stated.
And if you want the even look, OTG rear shims are the way to go. The camber shims aren't too bad either!
i am assuming camber shims are to fix the camber when you lower? mine isnt lowered.. the wife wants a smooth ride
Yes they will fit, you could even run a 25mm spacer in the rear.
negative ghost writer... camber shims give you even more camber... stock xB's have -1 degree so witht eh camber shims there will most likely (not in all cases) be -4 degree...
1 - 12 of 12 Posts
