1 - 10 of 10 Posts
Some oddness found unexpectedly in junkyard today. Is this really a legit oem thing? Cupholder led harness housed in center console with switch mounted next to Ebrake handle facing up. I'm thinking of elongating the 2 switch wires and using center slot in lower dash for switch since it fits there. Harness plugs into blue unused connector in my console since manual and auto stick not using it for lighting.
Technology Electronic device Electronics Electronic component Switch
Wire Electrical wiring Auto part Technology Cable
xB Leaving Pit Soon
It is Scion part number 08526-52801 Cup Holder Illumination kit. The installation instructions show to remove the floor console and cut out the switch opening which is scribed there. I had it there originally, but moved it to under the oven.
Discussion Starter · #4 · (Edited)
Yeah I didn't want to cut on console so I elongated the switch wiring and moved it under the oven too. Happy to have found this. Found none of the under dash and under seat lighting the lava was supposed to have so this made up for not scoring any of that......
Vehicle Car
Vehicle Car Center console Auto part Toyota
Vehicle Car Center console Multimedia Rim
Discussion Starter · #5 · (Edited)
I'm gonna put cupholder lights and the stereo display on mixer one night and check out how crazy that gets.........
just had chance to check it out tonite, pretty kooky.....had to go emerald ray on stereo and closest to that on cupholders. clear water bottle was fun.
Going with factory green footwell lighting until the footwell/keyring kit can be found
one I found in junkyard had switch mounted in center console by ebrake. I extended harness wires so switch could be in lower dash.
Yea I saw ur post looked good, keep mine simple and just installed it next to the e-brake / also next to the floor board light switch 🙂
Discussion Starter · #10 · (Edited)
I put the footwell lighting switch in front center of floor console between the cupholders...
Vehicle White Tire Automotive tire Motor vehicle
1 - 10 of 10 Posts
