My tail gate rear door won't open is there a fuse for this
there are $37 steel reinforced color matched ones on ebay. I bought one just in case mine decides to break. Since spare on hand oem will probably last forever, lolI had to hit a junkyard and pull a used part to fix my ride before I took possession of it. While I was there, I also grabbed a new plastic cover that bolts through the tailgate, those plastic pieces are flimsy and break so easily.
You are a bad influence Toaster bud, you just added another ebay listing on my car wishlist that's hanging around in my mind, and I thank you. Next mad money moment I have, I'll try to remember this.there are $37 steel reinforced color matched ones on ebay. I bought one just in case mine decides to break. Since spare on hand oem will probably last forever, lol
I had this issue and it turns out the rubber gasket around the hatch release button had melted/degraded and it was jamming the button in cold weather. I took the handle apart and cleaned all the rubber off using Goo Gone or maybe Greased Lightning, I can't remember. If you do this make sure to wear gloves because the old gooey rubber will get all over your hands and make a mess. After I cleaned off all the remains of the old gasket I wrapped the button in a latex glove so water wouldn't splash in it then reinstalled. That was a year or two ago and so far so good! You can also buy replacement buttons but I didn't think it was worth the cost when I could just repair mine.Just thought I'd share my experience with the rear hatch on my '06. It just won't open when it's cold. If I drive for ~20 minutes with the heat blasting and cycle the lock a couple of times it opens! When the temp is above maybe 45 F, no problem.
someone who has black and wants to save $7?........................or someone who wants to save $7 and add contrast trim color to whatever color theirs is?Who needs black when
Tailgate Primered Hatch Door Handle Garnish For 04 Scion xb 3Q3 Salsa Red Pearl | eBay
Salsa Pearl 3Q3 bits are available.
