Three silver knobs on center console; pull off with even pressure
hidden screws under knobs, ; remove
with fingertips, grasp top of center console and pull out toward you with equal pressure, the console will unsnap and become detached
unplug the three harness for the air control system and lighter, use a small flathead scrwdiver to lift the plastic latches
with the head unit now exposed, remove 4 screws , one from each corner, gently pull the stereo out toward you a few inches untill the back clears the dash,
now unlatch the two wire harness' using the small screw driver, and then gently pull the antenna wire straight out.
this should get the unit out,
just reverse the steps to install, if you are installing a single DIN unit, you will need an adapter kit to get it to mount in the factory double-DIN space. these kits are usually available at all stereo retailers. or you can order one from '' Crutchfield.com ''.
good luck, if you need more info, just holla, as my dash is apart at the moment, and I could send you some photos that might help.
