The World Famous
Hey there, Anyone know the stock spring rate on an xB? I need to soften the ride up some. and lower it about 1". Will the Tein Luxury springs be softer than stock? Any problems running them with 19" wheels?
Billy
scikotics
With a softer spring you lose handling but get a softer ride. You need to go to a progressive spring that give softer ride but stiffen up on cornering and when you put a load in back (passengers). Eibach are a good choice. If you only go 1 inch you will want more drop later. Most everyone I've talked to that has TRD or other one inch drop want to go a little more. Eibach sportline is approx 1.5 looks good without being to low.
scikotics
That will depend on the wheel offset. But if your looking for a soft ride 19's prolly not the way to go. Not enough tire to absorb shock. Springs won't make a differance. If your looking for a softer ride Stay with 15" or 17's .
Just my 2 cents.
OG Member
I have TRD's on right now and going to go with the Tein S tech's this week. They are going to drop me a little more (where my wife can't %^^&* to much).
I here you can change out your shocks for the Monroe and that will help out your ride from what I'm told.
RS4 #303
check here for good info
i bought progressive rate springs because i wanted a smoother ride over bumps and better performance than stock. got eibach's and im happy with the buy under 210 shipped w/ waranty they are 220 and change now :)
stock rate is 148fr 160rr my eibach pro kit's are 120-189fr 69-211rr
http://www.scionlife.com/forums/viewtopic.php?t=50481
bought mine here they have other brands too and were the best price for eibachs considering local tire store wanted over 450.00 installed :rolleyes:
http://ltbmotorsport.stores.yahoo.net/sceipr.html
