That little difference is definitely nothing to worry about.
Your calculations are correct, but keep in mind that this is only calculating on theoretical dimensions. The actual dimensions are going to be different based on manufacturer specifications, tread depth, inflation pressure, etc. The best you can do is to stay as close to possible to the OEM specs.
