There should be enough information on the links to at least try to make your own. If all else fails go to your local stereo shop. . . not Best Buy or Circuit City. . . and ask if they have a template. Chances are they've installed on a car like ours or have done one. It should be too hard, I half assed mine and I was done in under an hour or two. . . then again I've taken apart my door a hundred times and I had the Alpine crap ass bracket as a guide. Good luck, If I go into my front doors again I'll copy my template onto a piece of paper and get some measurements.
Ghosthunter said:
You could just put the stock speaker on a piece of wood, trace it and then cut it out with a jigsaw. That's what I did to mine and it took like 15 minutes to do both doors.
i got the fronts done i need the rears cuz i want a 6.5 in the rear
