I currently have some 15" Drag DR15's on stock tires. I will be puting in some Tein S-Tech's, Monroe 71575 Struts and Monroe 5870 Shocks soon! I then want to switch out the tires and add spacers? I want some advice? What does 195/55/15 or 195/50/15 tires with a 5mm front and 10 mm rear spacers sound like with my current wheels?
I wouldn't bother with spacers up front. If you want to do 10mm spacers in the rear I would seriously recommend getting the One Ton Garage HUB spacers.
The hub spacers space your whole hub out 10mm from your suspension and that way your rear wheels can bolt on normally.
I don't feel like making another thread, soo...
I'm dropped 2" in the back, with 16x7 wheel 205/50 tire and +37 offset.
Would a 15mm spacer work?
15mm would work if your rims are notched in the back to allow the original studs to poke thru.
cool, so the size won't be too big? good to know. I'll order some in a bit.
I'm at 15 off-set with 18x7.5 and Df210's, you should be fine with a 16x7 at 22 off-set. IF YOUR RIMS HAVE THE NOTCHES NEEDED.
