Ok a few of you guys have been giving me crap about doing a post to re-wire your side markers to stay on and blink with your blinkers .So here goes I've never done a D.I.Y. before so be gentle!
Passenger side:
1. behind both of your headlights there is a bundle of wires going to them.
2.Find the ones for your front turn signals.
3. Unplug your harness from your turn signals.
4. you will have to cut off some of the black cover, so you can get to the wires easier .
5. On the passenger side you will need about 5" of extra wire and a couple of wire crimp taps.
6. Find the white with a black stripe wire that goes back into your fender to the side markers and cut it as close to the headlight as possible.
7.Now you need to add the extra wire to the white w/ black stripe wire like this .
(Don't worry about the wire that is still in your harness.you are "not" tapping into the white wire you are running it to your front lights now.)
(the yellow wire is my extra)
8.Now take the other end of the extra wire and tap it into the (green w/ orenge stripe wire) that goes to your front pass side turn signal (( but don't cut the wire )) just tap into it.
see pic below
Drivers side:
1.do all the same but on the drivers side you will tap into the green wire " no stripe" and on the driver side you won't need to use extra wire.Just cut the white w/black stripe wire (that goes back into your fender)as close to the headlight as possible, it will reach.
Passenger side:
see pic below
Drivers side:
