1 - 20 of 23 Posts
Tool List:
Flat Head Screwdriver
Phillips Head Screwdriver
Ratchet with 10mm and 1mm deep sockets and a 12 inch extension
1) Remove the four 10 mm bolts securing the engine cover and the engine cover.
2) Unplug mass air flow sensor
3) Unplug harness from vacuum switching solenoid and vacuum hoses. (06 model earlier models will differ)
4) Remove crankcase breather hose from intake tube and valve cover
5) Loosen clamp securing intake tube to throttle body.
Thank you Sir. when i get my intake i will certainly use this for reference.
6) Unclip air box top.
7) Remove the upper portion of the air box.
8) Remove air filter element and compare with what is being installed (fun)
9) (more 06 differences) remove the vss from the air box
10) Install the vss won the included bracket (may need different screw)
11) Remove 10mm bolt securing the air duct.
12) Remove three 10mm bolts securing lower portion of air box.
13) Remove lower portion of air duct box from vehicle.
14) Disconnect and remove the battery. Starting with the negative terminal.
15) Install the bracket with the vss with the factory bolt and washer.
16) Install the short straight hose (2.25") with clamps to the throttle body (tighten only the throttle body side)
17) Install the filter onto the intake
18) Remove the mass flow air sensor from the factory air box
19) Install the mass flow air sensor on to the intake (note different screws may be needed)
20) Slide intake into fender well (this is a bit of a fit, but be careful of wires)
21) Install the vibration mount on to the battery tray.
22) Install intake into the straight hose and onto the vibration mount.
23) Tighten the remaining clamp on the intake side of the straight hose.
24) Secure the vibration mount with the washer and nut
25) Plug the mass flow air sensor up
26) Reinstall the batter and secure it with the tie down.
27) Install the 15.9mm vacuum hose onto the crankcase breather and intake pipe and secure it with the factory clamps.
28) Do a second check to make sure anything that was moved is plugged in. Especially watch the vss and maf!
29) Install the engine cover to complete the install.
Finally have fun:D
It is an automatic. I don't get into the throttle too much, but my wife says she can feel some gains and says that it doesn't take near as much throttle to accelerate.
She did say that she burned some rubber today without even trying.:D
After reading through it there is one typo. The other socket is supposed to be 12 mm not 1 mm.
Don't have any fog lights. Sorry. I think this one seems to be high enough not to get in the way.
what about you gaas mileage?? did it improve it?? juss curious.
Discussion Starter · #13 ·
Dont know yet. Just got it installed and it cleared the trip when I unhooked the battery. I will let you know later this week though.
thanks i installed my intake today, they helped!!! now my box is one step closer to being the best box around east texas, all i need now is my rims (comming soon) the body kit (on order) and a pain job (dont know when im getting that.... then i shall cont. to make it my own... muhahhaa
i gotta know where ya got it man can ya tell me??? wait before anybody tells me use the dam search button. i am directing this question for shortbus. maybe he got it from a local shop or something where it can be picked up. hey ya gotta help the little guy survive somehow.lol..
Discussion Starter · #17 ·
Its an ebay item. Just be patient and you can get it for around $120 shipped. It really is a good sounding and quality part. I have been very pleased thus far.
great write up! alot easier then i thought. the write up looks alot harder then it truly is.
helpfull, did my injen cai in record time:D , don't work on your box on the street next to a drain, thats a good way to lose a socket:eek: :p
The ydr is the same as the fujita but cheaper, you can damn sure hear the sucking of air with the short ram. And the ydr comes with a K&N filter as well.
Ebay, $69 with free shipping
1 - 20 of 23 Posts
