1 - 8 of 8 Posts
Scion XB 08+ Megan Racing Coilover Dampers
Had this on my 2008 scion XB for about less than 10,000 miles
I was running Work Euroline DH front 18x8.5 rear 18x9 and with the coilovers.
selling because im planning on running air suspension.
comes with the original box little beat and everything else you prob would only need to reused one screw from your existing suspension.
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
SPECIFICATIONS & FEATURES:
APPLICATION:
Scion xB 2008+ (Do not fit Toyota Bb)
SPRING RATES:
F: 62mm ID; 180mm length; 5 kg/mm
R: 62mm ID; 180mm length; 4 kg/mm
DAMPER SPECS:
F: 130mm stroke; 280mm length; M2 valving code
R: 175mm stroke; 300mm length; 44R03 valving code
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts w/ Front Adjustable Camber Plates
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
1 - 8 of 8 Posts
