(CA will have tax added, Priority shipping is included!)
Check out all the features of the ScanGaugeII on my site!
Group Buy Closed..Thanks to all for participating!..clubXb Price in effect!
Pretty cool little units they give you the ability to monitor many functions, check error codes, clear "Check Engine" lights, built in trip meter..much more check them out!
One of the feature I like is the voltage gauge, nice to see how much your system is draining! Tons of stuff in a small product..check it out on my site for additional information.
Also cool to check your intake air temp and see if that CAI is really working for you!
Info
SCAN TOOL
The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
Reads Trouble Codes
Reads conditions that set the Trouble Code
Clears Trouble Codes
Turns off the "Check Engine" light
Tells you when vehicle is "Ready" to pass OBDII testing
Make and store up to 10 rewritable special codes
to send to the vehicle computer
DIGITAL GAUGES
Display 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Distance to Empty
Time to Empty
Fuel to Empty
