is anyone runnin on a lo pro, wide lip 15's, w/ a 2in. drop, flush w/ the fenders on their xB?? any pics?
thanks
thanks
thanks squirrel, btw is da "werks" site still unda konstruxion? can't wait to see all da good stuff on it brah =)squirrel said:I'm not sure about the 2 inch lip, but there are some who run wheels w/ low offsets to fill the wheel well, and have a mild stretch on the tires.
nice.youthinasia said:me! work equip 03 15x8 25/10, s-techs sagging beyond the advertised drop.
get well......now hurry up will ya =)squirrel said:Yeah, once I'm healed up, the site will be my prioirity.
Q: w/ da lo profile tires w/ 15's w/ 2in. drop, will i still run into issues w/ da fenda?youthinasia said:Just keep in mind that with the low offests, and having the rear lip flush or sticking out, will probably require rolling or trimming of the fender lip. Especially if you have a drop.
And when you attempt to roll the rear fenders, do it when its warm or het the paint slightly so it doesn't crack.youthinasia said:Here's my experience. Rear offsets, + 10 to +15 with 195/50 or 205/50, will rub with an S-tech drop (1.5-20"), requiring rolling or trimming of fenders. With the +10 offset, the lip of the rim is sitting about 1 cm beyond the extreme edge of the fender at it's widest point. It looks good with a stretchedtire, but the inside fender lip will rub over bumps.
No trouble with rubbing in the front with a 25 offset, which brings the lip flush with the fender.
TO be safe, with no rubbing, go with 25 offset all around. You won't have the extreme wide rear lip, but you wont have to modify the fender.
That being said, modifying the fender really isn't a big deal if done right.
I tried to roll them byself witht he baseball bat method, but it is kind of dificult because the rear fender is double-layered with some rubber material sandwiched in there and is thick.
I had them cut and it is fine now...no rubbing, took about half an hour. It's clean, and you can't even tell they were modified at all.
If you are in socal, and want them cut, pm me and I'll recomment the place to you..........they're pretty awesome. Just remember to paint the exposed metal after they are cut to prevent rust.
BTW, +10 on the rear, for the works will get you the maximum wheel lip, which is about 3.5 inches.
I used the Baseball Bat method in my Civic hatchback but noone told me about the Heat issue (and I live in Seattle where it's COOOOOLD) so my paint cracked pretty bad around the lip. I'm not gonna lower my XB.....well at least not for a little while, I have too many other projects to do to it first.squirrel said:And when you attempt to roll the rear fenders, do it when its warm or het the paint slightly so it doesn't crack.
I used the baseball bat method also.
Yup they are the new sportmax's for teh AE86. They come in Red, silver, black and gunmetal and only come in 15 x 8 with a 0 offset. That means 3 inch lip all the way around! If you want them, bBist is having a sponsored sale on Scion Life. ONly $100 per wheel which is really cheap!ThunderGod said:Ok Cassidy, what kind of wheels do you have on now. I likey =)
