1 - 10 of 10 Posts
I tried to do a search on the forums and can't find much information on replacing the drums on the xB.
When I removed the rim and the locating ring on the hub there are 2 holes that can be used to pull off the drum from the hub assembly. Does anyone know what size bolt I'm suppose to use? I also tired banging the crap out of the drum with a hammer with no luck. :confused:
Thanks!
-B
Make sure your parking brake is off.
Make sure your replacement shoes come with the adjuster plate pin already installed. If not, you will have to buy a whole hardware kit from the dealer. They do not sell this pin seperately.
It's a crimped in pin so you cannot re-use the old ones.
I found the correct screws. They were 8mm x 1.25 and sold at Home Depot for $0.29 cents each. After replacing the shoes I smeared anti-seize on the hub snout to prevent it from rusting together again.
-B
What brand shoes did you use?
Did they have the pin for the adjuster plate already installed?
if not, what did you use to crimp the new pin in with?
I bought the Bendix Global brand of shoes and they cost about $22.00. They already had the pin for the adjuster plate installed so in was pretty straight forward.
-B
Hey Blown or anyone else listening! Saw your post on brake shoes, where can I get "Bendix Global" shoes? My wife has a 2005 XB and I just paid $90.00at AUTOZONE and I dont believe that they come with the "adjuster plate". PLEASE HELP.......
Jazzz
Sacramento, CA
the bolt size to get the drum covers off is a 10mm i took them off just the other day. and don't buy them at auto zone oreillys etc..... way too expensive get em online or i think pep boys has some pretty cheap ones.
I'm gonna change mine soon and take some pics and post a DIY pretty soon
The bolt size is 8mm x 1.25
1 - 10 of 10 Posts
