1 - 14 of 14 Posts
open the hatch, behind each light you'll see a plastic piece which will be taken off.
There are 2 10mm bolts holding the lights on, it's a tight fit with a socket wrench.
undo the wiring harness, and pull the tail light off the car.
Thanks man, jus got sum new led lights and no money to install them.
unless you don't mind blood knuckles...also push the tail lighght while you ratchet to help you losen the seal.
Don't underestimate this piece of advice. I didn't think of it until I was putting them back on!
Just don't let the tool beat against outer skin of the quarter panel. Will dent easy.
Glad i didn't do that, because i have a habit of letting the ratchet band against whatever...i guess its because i'm lazy
1 - 14 of 14 Posts
