1 - 18 of 18 Posts
Do you really have to take the front bumper off, just to remove the headlights?
Sounds pretty wierd :eek: if you ask me. i want to clear my headlights, but this sounds like i need a few people if i have to take the bumper off to release the lights.
Can anyone give me some feedback on this :confused:
It is true, you have to take the bumper off to remove the headlights. I did it by myself. The bumper doesn't weight anything, just make sure you have something soft to place it on while you're working on the lights so it doesn't get scratched.
Ya surfcitylocal is right! Only takes a few minutes to remove the bumper and its really light! It can easily be done by yourself!! Shouldnt take more than 10-15 min. tops to remove the bumper and lights if you know where all the bolts and screws are!! I also agree that you should lay a towel down on the ground so you wont scratch the bumper!!!
You don't have to take it off completely, you can leave the bolts are underneath on, and rotate it away from the box, just enough to take the lights out and have some room to work with...thats what i did
This is True - I only removed the top bolts...... The catch is there is a tab on the bumper by the lights that takes some manuvering to get the bumper to release.....I think SurfCity posted a pic somewhere....best of luck
Yep...i think i was fighting with it and it was already alose...
Here's the tricky little tab...
I knew you had it ........ Mister DIY to the rescuse................
Always glad to be of service.....makes me smile.
DTRAIN619 said:
Yeah, had to fight with that pesky tab as well, but the results were worth it!
Looks like me twin now that we both have the lower billets on. Brotha's from anotha mutha! :D
Quit being negative. Especially as your first comment.
RS4.0 #1526
There are 2 under the grill and 2 in the fender wells. One on each side at around the 10'oclock position if you are looking at the drivers side wheel. Then like 7-8 underneath the lip starting at the very edge of the bumper working it's way in.
1 - 18 of 18 Posts
