Anyone know how the instrument plastic (covers the tops of the instruments) is held onto the main dash plastic? I need to remove the long plastic instrument cover.
thanks
If you are talking about a 1st gen xB, look under the upper flat section to the right of the speedo. You will see a black phillips head screw. It is plastic and about a size 1 phillips. It will have to be short because of the angle. Hard to see without a flashlight shining on it. Also easy to strip out the head, so be careful. Once it is out, rest of the cover should pop out. It's been couple of years since I pulled one, but remember the screw can be a bugger.
I have a second generation (that's why I posted my question where I did), so still looking for help.
---------- Post added 05-17-2015 at 05:33 PM ----------
How do you go back and edit postings on this forum???
Just wanted to add that the plastic I am referring to surrounds the driver's side air vent as well, which it appears some already know.
Sorry, missed that.
Dang it, link pulled up 2nd page instead of 1st page.
