1 - 2 of 2 Posts
Randomly today my read break lights are stuck on. Even when the lights and car is off the lights stay on. Is there a switch or connection I need to check to fix this?
First place I would check is the brake light switch that the pedal pushes on when you press the brake pedal......maybe it is worn and the plunger stays depressed after you take foot off pedal. Follow brake pedal up under dash, switch should be below where pedal pivots up top.
1 - 2 of 2 Posts
