I built a box something like the box you can find on eBay for under the front seat( downfiring)
And this is the sub I chose, $95 (new at fleamarket)
What I noticed:
Sounds great.
Can't tell I have a system.
Cheap.
Sweet engineering.
Recommend!!!
Introducing the Premier® TS-SW124D shallow subwoofer from Pioneer, featuring a revolutionary design with just 4" total depth (just 3-1/4" mounting depth!). This revolutionary new subwoofer provides the body-rumbling bass of a fullsize 12-inch sub in a package that fits almost anywhere
Size 12"
Woofer Cone Material Double Cone Construction using Carbon Fiber and Kevlar® Branded Fiber Composite IMPP Cones
Surround 3-Layer Fiber Woven Radial
Voice Coil 4-Layer, Long Voice Coil (4ohms)
Voice Coil Bobbin 8-Slit Glass-Imide
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Silver Binding Posts
Specifications
Watts MAX. Music Power 1200W
Watts Nominal Power Handling 300W
Frequency Response 18Hz ~1kHz
Sensitivity 88dB
Ohm Rating 4 Ohm
Recommended Enclosure 0.6 ~ 1.0 Cubic Feet
What I noticed:
Sounds great.
Cheap.
Sweet engineering.
Recommend!!!
Size 12"
Specifications
Sensitivity 88dB
Ohm Rating 4 Ohm
