1 - 4 of 4 Posts
-=(( Gcat ))=-
So I'm looking into a system for the box. This is what I've window shopped for so far. I've liked the SONY systems for a long time and think it would be good to not mismatch things and go for a solid theme. I really have no clue about the Amplifier and if I'll need one or two and how many channels. It's been awhile and I'm just looking for pointers, tips and advice. So tell me what ya think?
SONY CDX-FW700 CD PLAYER
* 4 x 23.2 watts RMS
* 4 x 52 watta Peak
* 3 Pairs of 2-volt preamp outputs
* Fluorescent display
* Dynamic Soundstage Organizer
* SSIR-EXA tuner
* XM Ready
* CD/MD Control
* CD Text
* Flip-down Detachable Faceplate
* Auxiliary Input
* High-pass and low-pass filters
* Clock
* Wireless Card Remote
SONY XS-F1721 6 1/2
# Maximum Input Power -- 140 W
# Rated Input Power -- 35 W
# Impedance -- 4 ohms
# Sensitivity -- 90 dB/W/m
# Frequency Response -- 35 - 30,000 Hz
# Mounting Diameter 139 mm (5 1/2")
# Mounting Depth 46 mm (1 13/16")
SONY XS-V1340H
5 1/4" 3-WAY 200 WATTS CAR SPEAKERS
* 5 1/4" 3-way Speakers
* 200 watts Peak each speaker
* 50 Watts RMS rated each speaker
* Hot New cosmetics
* designed for better sound
* H.O.P. Woofer
* Nano fine balanced drive midrange
* Built in tweeter
Sony Xplod XS-W4021 4" COAXIAL SPEAKERS
polypropylene woofer
PEI balanced dome tweeter
frequency response 45-22,000 Hz
power range 2-20 watts RMS
peak power handling 120 watts
sensitivity 90 dB
depth 1-11/16"
XS-LD105P5 P5 series 1200W Subwoofer 10"
* 1200W Peak power
* 350W RMS Power
* Aluminum Deposition Cone Design
* Dual 4-Ohm Voice Coils
* Double Damper Suspension
* Dual Stacked Magnets
* Rear Voice Coil Vent with Vented Heat Sink
* Gold-Plated Binding Posts
Sony XS-LD125P5 12"
# P5 Rigid Aluminum Deposition Cone Design
# Dual 4-Layer Voice Coils
# Durable Foamed Rubber Surround with Stroke Stabilizers
# Double Damper Suspension
# Dual Stacked Magnets
# Gold-Plated Binding Posts
# Rear Voice Coil Vent with Vented Heat Sink
# Optimized for both Small Sealed and Ported Enclosures
# Mounting Depth: 5.88"
# Rec. Sealed Box Dims: 1.00 cu.ft.
# Rec. Ported Box Dims: 1.50 cu.ft.
# RMS Power Range : 125-500 Watts
# Peak Power Handling: 1400 Watts
# High Frequency Response: 2500 Hz
# Low Frequency response: 18 Hz
# Impedance: 4 Ohm
2006 Sony Xplod XM-1252GTR Competition 2 Channel Amplifier
XM-1252GTR
2/1 Channel Amplifier
125Wx2 @ 4 ohms
340Wx1 @ 4 ohms
800W Max Power
hit me up i got a box if your interested for a 12 in your storage space on the right side trunk....lemme know..in san diego also
-=(( Gcat ))=-
is it the fiberglass one? got a pic? How much?
even though i can tell you right now it's all in the near future just not soon enough. :(
1 - 4 of 4 Posts
