1 - 10 of 10 Posts
I have a 05' XB and the stock pioneer deck always says Error 04 whenever I put a "burned" disk in to play. Am I the only one with this poblem. It even occures with some new disks too.
Its still under warranty. 29k miles. Any sudg. Should I have it replaced? Am I the only one with this problem?
Any tips are helpful. Thanks J
Error 94 is can't read the disk. I think I'll run it into my local dealership and have it exchanged out. Thanks for the info:D
You might want to try a lens cleaner disc if you haven't already. Worse case scenerio, they simply give you another player. Good luck in either case.
do any brand of cd-r's work in your changer? when i had a pioneer changer it would not play the cheap brand of cd-r's if thats not the case then possibly its just a bad head unit.
Well the head unit took a crap. The changer jammed and would not eject or play any CD's. I think it was just a bad unit. Toyota has replaced it and its working great with all CD's.
Thanks Guys, J
1 - 10 of 10 Posts
