1 - 10 of 10 Posts
I need to know what kind of amp i need to PUSH my subs..
right now..
PIONEER 760W GM-5100T
• 125 Watts x 2, at 4 ohms <= 1% THD+N • 380 Watts x 1, at 4 ohms BRIDGE <= 1%•THD+N• 95 dBA Signal-to-Noise Ratio (Reference: 1 Watt •Selectable 50Hz Bass Boost Output)• Built-In Crossover (80Hz Low-Pass Filter)•Speaker Level Inputs
w/
2 12" PIONEER Premier® TS-SW124D
* Watts MAX. Music Power: 1200W
* Watts Nominal Power Handling: 300W
* 4 Ohm Rating
* 4-Layer Voice Coil, Long Voice Coil (4ohms)
What kind of amp should i invest in?
All i know is I need a 2-Channel but I don't know about the ohms or RMS.. :(
I have a Really cheap Boss 850w that pushes mine just fine, and I think one can be had for around $50.
I'm thinking of doubling up on each, for under the drivers seat.
well I only have 760w for two.. what kind of amp shud I get to push 'em?
and if u do plan on buyin one.. bargainunlimited.com has'em for a decent price..
From what I have, I bet about 1200w would be perfect.
cool.. bcuz I was thinking of buying the premier 1200w amp from ebay :]
That should do it.:)
make sure it matches... dont necessarily buy one from the output look at RMS and what Ohms it puts the power out at. is it single or dual voice coil and are you hooking up series or parallel? this can make the difference in sounding good or sounding great...
this is what i found out about my subs.. what kind of amp would u prefer?
Woofer Cone Material Double Cone Construction using Carbon Fiber and KevlarÆ Branded Fiber Composite IMPP Cones
Surround 3-Layer Fiber Woven Radial
Voice Coil 4-Layer, Long Voice Coil (4ohms)
Voice Coil Bobbin 8-Slit Glass-Imide
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Silver Binding Posts
Watts MAX. Music Power 1200W
Watts Nominal Power Handling 300W
Frequency Response 18Hz ~1kHz
Sensitivity 88dB
Ohm Rating 4 Ohm
Recommended Enclosure 0.6 ~ 1.0 Cubic Feet
Sensitivity 88dB
Ohm Rating 4 Ohm
if thats the spec of your sub all you need is about 1000 want amp at like 500W rms each channel if you want im selling and amp its a really good amp an arc audio 2500 cxl heres the spec
Features
* Dual Sided 4 Layer PC Board
* Variable Speed Fan Cooling
* Unique High Efficiency Power Transformer
* 500 Amp Switching FET Power Supply
* High/Low/Full Range Selector Switch
* 50Hz – 5.5kHz Variable 12 or 24 dB/Octave Crossover
* 0-18dB @ 45Hz Variable Bass Boost
* Reverse Voltage, Over Voltage, Speaker Short, and Thermal Overload Protection
* Power Save Mode for Longer Low-Level Playing Time
* Heavy-Duty Construction with Cast Aluminum Heat Sink
* Deluxe, Audiophile Grade RCA Connectors
* RCA Pass-Through Outputs
* Damping Factor: >2000 @ 1kHz, Slew Rate: 60V/uS
2-Channel Amp Specifications
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 250W x 2
* THD at 4-Ohm RMS Power: 0.05 %
* Bridged RMS Power @ 4 Ohms: 1050W x 1
* Speaker Level Inputs: no
* Preamp Outputs: yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0-18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >105 dB
* Dimensions: 18 L x 8 W x 2.35 H
pm if you want it
1 - 10 of 10 Posts
