1 - 10 of 10 Posts
Towster ['__'`,-,
I started my xB for the first time in almost a week. The car started with a horribly rough idle for about 10 seconds, then mellowed back to a normal idle. I left it idling for another few seconds, and then the Check Engine Light came on.
P0301 code was thrown. So I decided to clear the code.
I turned off the engine and then restarted it again. Engine started flawlessly as normal. No roughness. And no Check Engine Light.
Should I be concerned with this at all? I have driven about 50 miles since the incident without any additional problems. What is everybody's opinion?
Pishtaco
Probably not a problem. You might want to swap ignition coils between cylinders 1 & 2. Then if you get a P0302 code next time, you'll know the cause.
  • Like
Reactions: 9.0 2012 RS
06.5 TCM
It's OK to drive for some time with the light on steady, but get it fixed asap.
Never drive with the the check engine light flashing- that's for sure.
Pishtaco
  • Like
Reactions: PCH
06.5 TCM
Rep points for posting that link Darrell.
Most common ones: spark plug, bad ignition coil, valve problem (not enough clearance, burned seat area, bent), broken valve spring, low cylinder compression.
Towster ['__'`,-,
So the problem is probably because the car has been sitting for a while.
I did reset the light and it has not come on again so I think it is clear sailing. It runs like new!
hey u guys i have a 2005 XB and i have a miss fire on cylinder 1 and i changed the spark plug and coil pack. but still no change, it still shakes. i also checked the injector and i am getting a pluse, i haven't changed the injector need help.
1 - 10 of 10 Posts
