What do you guys think of this? It apparently sprays nitrous over your intercooler which helps to reduce the air temperature even further thereby increasing HP. Interesting for those of us with turbos or superchargers.
i personally would think you would get mre hp by using the nitrous IN your engine rather then spraying such an expensive liquid on your intercooler... maybe im justing thinking too simple mindedly. (i cant spell that for shi!)
no it works but not in the way nitrous traditionally works..it does add a little hp cause it still goes thru the intake in a sense...BUT boost is hit much faster and harder since the air going thru is COLD how cold? ICE COLD =P
well there is a cry02 system that sprays your inter coller and freezes it a buddy of mine has one and when he sprays it is coats the intercooler with ice
via Co2 gas witch by the way is the same stuff used in paintball guns it is veary affective
Hotbox05, so you're saying the nitrous system is better than the CO2 system? The only thing is doesn't it cost more to refill a canister of NO2 than CO2?
