Well,
It's been a very long time since I've been on this forum, but I'm finally getting a system in my car again and figured I would share.
Subs: (2) Sundown SA12
Sub Amp: Rockford 1200d (birth sheet shows 1300 actual rms)
Enclosure: 4 cubes net, (2) 4" aero ports tune to 35hz
Speakers: JBL GTO (fronts only)
Speaker amp: Kenwood KAC1502s
HU: Kenwood DDX 419 (I've had this for a while)
Clarion Equalizer
GTMat sound deadener (had an amazon gift card, and it was cheap)
Discussion Starter #5
Alright!
finally got everything installed. Took a bit longer than I anticipated, mostly cause I don't really have the right tools for this stuff anymore, had to make several trips to the hardware store and such.
---------- Post added 05-12-2014 at 06:58 PM ----------
I got both amps, equalizer, and the distribution blocks to fit perfectly under the seat. You can barely see the wires except for the power/ground coming from the component amp. Granted, you can see the wires if you actually look under the front of the seat, but the back is totally clean, even with the seat all the way forward.
Plus, its packed in there so tight that you can't get it out without removing the seat.
---------- Post added 05-12-2014 at 06:59 PM ----------
Also, since I took the pic I replaced the piece of plastic around the right side of the seat, so the ground wire is covered
Discussion Starter #7
Thanks man. I'm pretty happy with it. As always, it could have turned out a little better, but overall it's hidden well and it slams.
