1 - 20 of 27 Posts
Check out these Stealth turn signal bulbs, no more ugly amber bulbs.
They look chrome until in use and then they light up amber just like they are supposed to.
You can get you some at www.zetaproducts.net
I got these at Pep Boys last year for about ten bucks. I love 'em!
Hey I just cleared my headlights this morning. I'm going to get some silverstar ones tomorow at advance auto parts.
i just got some Led turn signal bulbs but I was told that I would need a resistor or else I will blow fuses...is this true?
pimptastic jon! i like your headlights man, did you smokem out or something different?
stephanie, im rockin the Sylvanias in my turns. Good bulbs.
PEP BOYS THATS IT TAZ I HAVE THE SAME
ASK TAZ THE LED KING
Sorry to threadjack but I thought I could help BigWill184 out on his issue with LED bulbs and give some others my experience with them. If you want a great place to order high quality LED's at really good prices look up Velocity LED's on Ebay.
I had all LED's for my turnsignals as well as side marker lights. The problem you'll run into is that the LED's draw far less power than the stock filament bulbs and will cause your blinking rate to increase because the computer thinks you have a blown, or damaged, bulb. I installed a relay built for LED use and it cures the rapid blinking rate and all the LED's functioned just like th bulbs they replaced. You can get the relay here: http://www.superbrightleds.com/tail-brake-turn.html
Just scroll down to electronic LED flasher, click on it and it is the last one on the list.
Only problem I had was that the light pulses on the lock and unlock of the doors didn't work.
Hope this helps, threadjack over:)
thanks for the help....
hahahaha, thats funny!
i got the silverstars ans am happy with em
You will only need one relay for all your lights, it replaces the factory one on the fuse panel under the dash.
Hope that helps, later!
FYI - You can just spray your amber bulbs with some silver paint. Just use 1, 2 coats MAX and they look just like those pictured, light up amber, but are a fraction of the price.
Regular abUser
I got my silverstar corner bulbs $9.99 for the pair. They have a blueish color to them but light up amber. I'm very pleased with them and the cost.
Here is a pic w/ them off
and one with them on
1 - 20 of 27 Posts
