I finally got it done. I painted my engine cover and added some chrome lettering I ordered from Randode.com
DTRAIN619 said:Oooohhhhh, Ahhhhhh!!!!!!!![]()
Looks good, how much sanding did you have to do?
Nice! BTW, I'll be shipping my cover to you!!Ghosthunter said:Thanks. Actually, not a whole lot of sanding. I sanded the cover down when I first started. I used some 800 grit paper so I wouldn't put any scratches in the plastic. I then sprayed it with primer, then gave it a once over with the 800 again. Then about 3 coats of the base coat (silver) for good coverage. Again the once over with the 800. Then I started with the final color, which is actually Red Metalcast paint. I put a total of 10 coats of the red on to get it the color that it is. If you make sure that the surface is very clean in between each coat, very little sanding is required. After the red, I put the lettering on it, and then applied 4 coats of clear.![]()
hayalex6 said:What kind of paint are you guys using for all of the plastic pieces?
Looks like something I'll be doing this weekend.
