hey guys i know that you guys no that i have some volk 18 inch te37 i dunno the offset but i have some 215/35/18 on but i need new tires in the rear and want to go with 225/40/18 on the rear and 215/35/18 in the front on some tein s-tech spring i was woundering will the 225/40/18 in the rear rub thanks need to buy tires today thanks
you may run into rubbing issues on the inside of the tire along the trailing arm. is there any reason you want a wider in the rear when its the same size wheel? 225 40 will not only be wider but taller as well, so it will add some rake yo your car
brent
If you want 225/40/18's i got some for sale. I havent posted it yet but there are Yokohama Prada Spec 2's with less than 500 miles on them. You wont have any rubbing issues. Ive seen a guy with 225/40/18 on 18 x 7.5 on S-tech's and he said no rubbing issues.
hey matty how much you want for the tires
With a front wheel drive car, you should have the wider tires in the front & the thinner tires in the rear. This reduces understeer & improves handling. I'd just get some 215/35-18 tires again.
