1 - 16 of 16 Posts
I was wondering if this rims would fit in our car without spacers or lowering the car. My friend is selling a 17x7 4 lug motegi FF7 with +42 offset. does this rims would fit in our cars. can you guys let me know right away. thank you
The bolt pattern has to be 4X100 and not too sure about the offset.
that offset is fine, mine are +40 17x7... you'll just need to get like 20mm spacers, as i was told for mine...
you will only need spacers if you want that "flush look". i believe there is a whole thread on spacers and spacer sizes in the wheel and tire section.
i personally have 17X7" wheels w/40mm offset and i love the way they look.
the big concern is to make sure they are 4X100mm lug spacing.
exactly my point, but it also looks better when its flush...
the brave little toaster said:
u will need spacers in the front. i rub on turns. i have a 42mm offset, 17x7
what spacers are you using? where did you get them? i might need spacers also coz i hear something when i turn my wheels all the way...
Spacers for sure! 25mm atleast. I'm running a 25mm with 18 x 7.5 and 5mm on front.
u can pick up spacers online cheap but for quality get OTG.
i have 5 mm in the front so i dont rub the hell out of my wheel well anymore
want to get 10 in the rear to flush it out.
i have no spacers with 18's 42 offset, the only problem i have is if i turn all the way to the right and back it catches the plastic liner on the front and snapps back. but that is no problem at all, no rubbing
Hmm, I was running 17x7 Konigs with a +42 offset, 215/40 series tires, no rubbing whatsoever on the front...
Discussion Starter #15
is there a website i can get a spacer then for my MOTEGI FF7 17x7 +42 offset. and what size in the front and the rear
1 - 16 of 16 Posts
