1 - 8 of 8 Posts
xB Leaving Pit Soon
If your xB has stock side skirts, there is one fastener at each end underneath a circular cap, along with a few plastic retainers attached to the body along the length of the skirt. The cap has a small notch where it can be pried to remove the cap. Use a pry device which is hard plastic or wood to avoid scratching the cap or the skirt. When yours came loose, hopefully the cap was in place and the fastener is still inside. Be sure to reseat the tabs into the plastic retainers.
Frank
Since it's loose and when I go to put it back in do I need any other accessories to put it back on or will you simply clip back in?
xB Leaving Pit Soon
Unless any clip or fastener is missing, the skirt will reattach by pushing in the middle section clips and by tightening the Phillips head 10mm bolt under the circular caps.
Frank
Old School xB Builder
My 05 xB driverside side skirt has come loose. What can I do to make it tighter again?
Look under it there's a bunch of black push in round clips. under the snap out covers in the front and rear next to the door there's one Bolt in each
Sent from my LG-LS997 using Tapatalk
Has plastic pop in retainers on the bottom that are oval shaped. Possibly knocked them out. The upper ones should snap back in place and 1 screw on each end under decorative cover. I happen to have a handful of those lower retainer clips if you can't find any.
1 - 8 of 8 Posts
