Okay i just put on my sportmax 962's running 18X8.5 in front and 18x9.5 in the rear what specs is it for the extended wheel studs? i know someone told me to remove at least one to show what i need but this is my only ride to get around so if you guys know the size let me know thanks
im running spacers the OTG spacer shim and also there 5mm wheel spacer so a total of 15mm and this is only for the rear... thanks for your guys help
you wont need extended studs then. the 10 mm OTG shims push the hub assembly out 10mm so that negates having to get longer studs. as for 5 mm spacers, im running them with no spacers now and its just fine. you dont need longer ones for just 5 mm spacers. you're fine how it is.
You don't need the extended studs.
