1 - 5 of 5 Posts
Hi all, this is “Pandora”. So I know you all have seen so many different looking xBs, and mine for the majority is still stock on the outside and under the hood. So currently at this point, this is my 2006 xB generation 1 with 91,xxx miles that I picked up for 4,935.00.
I have done the following, but I have yet to install the rest of the goodies that await:
• Drop in performance air filter
• Accel super coil packs
• Brisk Evo spark plugs
• alternator/ generator v belt adjuster(it’s a turn buckle that has spherical rod ends on it)
• Amsoil motor oil
• Sickspeed shift knob
• OBDLink LX Bluetooth obd2 port adapter to allow me to display gauges on a tablet behind my steering wheel
• Magnaflow high flow catalytic converter
• Vibrant resonator
• Eagle Eyes projector headlamps with low beam halo rings
• exhaust bypass valved kit
• stainless steel exhaust pipe for the open header outlet side
• two burnt exhaust tips
• Premium Auto Styling windshield banner
• switchback white/Amber blinkers
That’s what I have installed currently. A few other parts waiting to go on soon I hope. These are:
• B&M short throw shifter
• clear vinyl protection for the headlamps
• DRL switchbacks for the fog lamp location
• light tint over taillights
• usb x4 for the back and front passengers
• new Powerstop complete rear drum brakes
Other ideas are in mind and I’d love to use vinyl or paint to make them happen. I even have to do some painting to help pretty up the engine and calipers and drums. But for now, this xB will get one more badge debadged and wire mesh added to the vehicle.
Thanks for reading about my xB!! 7CD24249-401F-4A4F-AC7E-077C84C95A3A_1558369904602.jpg CD6A384E-BEC5-4971-8794-3482197D0D8C_1558369839331.jpg E24B3113-1196-47D9-96FD-534D2C18A42D_1558369821172.jpg D43C7255-706D-424E-B7E0-4DF448064BD1_1558369790380.jpg 06A36F88-5F35-439A-ABD9-EE609682E924_1558369763259.jpg
And some more...
One thing about this vehicle is I gave her some attitude in her voice. That’s the toggle switch to open and close it. DD6FDD05-A832-47D7-85E7-CB8673B3F3DF_1558370420791.jpg
A bypass valve kit to drive with open header whenever I feel like it and can close it on command.
408E8673-4F99-4062-8AB6-0539D6CF1432_1558370388707.jpg F0784A47-EF5A-410E-B711-1D0A5EB659CC_1558370356776.jpg 5D3735DF-59A9-4FA7-8574-11D518C6E166_1558370331990.jpg 24707F6C-1723-45FD-B13A-BC789BCEA2D7_1558370299140.jpg
And some more...
One thing about this vehicle is I gave her some attitude in her voice. That’s the toggle switch to open and close it. View attachment 73348
View attachment 73346 View attachment 73344 View attachment 73342 View attachment 73340
So I have a 2008 XB but always having problems with the AMF system and because of the problem she doesn’t have as much power when accelerating I have changed the sensor so many times and still dose the same problem with Computer codes giving me problems with AMF dose any body here can help or Guide me the right way to illuminate this problem that I’m having in the codes.
Discussion Starter #5
Clear code if you haven’t done so. And I’d suggest using a mass air sensor cleaner over buying a new one. Unless your’s was damaged some how. I’m just learning about this vehicle and I don’t know what I could help figure out for you. I actually had to have Toyota dealership make my Mishimoto Air/Oil separator work for me. Best 119.00 dollars I spent on a service department appointment.
1 - 5 of 5 Posts
