1 - 8 of 8 Posts
Lurkin'
I know a few people have hooked up mechanical oil & temp gauges in the B's, any tips on install and where did you "tap" in for each gauge..I dont trust the "idiot" lights !!!
There are adapters that go inbetween your oil filter and the block with connections for the oil sender unit. The oil temp is done the say way, most of the adapters have multiple connections. If you want water temp there are temp sending units that install in your radiator hose. These are two of the more simple ways to do it.
This is one of the GReddy oil block adapters:
You can find them on line.
http://www.coximport.com/auto-parts/prods/12002801.html
Here's a site with a list of adapters for different gauges:
http://www.sfxperformance.com/searc...ters+and+Senders&MainCategory=Gauges&type_id=
Yeah, try to run the same adapter as the company you are using for your gauges. The GReddy adapter uses a different thread pitch than say, AC Autotechnica.
Excellent point, Smithers
One thing, since we don't have the gauges to begin w/what should the xb be running for Oil/Water temp and Oil pressure?
1 - 8 of 8 Posts
