are the bumps stops required on all four corners or just the fronts?surfcitylocal said:The bump stops are inside the front coils. You can cut the bottom one inch off if you are doing a 2 inch drop. Your springs should come with directions on how to do this. It's simple.
thanks for the info!zobispo said:just the front
